ONTAP 9.9.1 commands
vserver vscan connection-status show
Display Vscan servers connection status summary
The vserver vscan connection-status show command displays connection status summary of the external virus-scanning servers, or "Vscan servers" for a Vserver. If you do not specify any parameters, the command displays the following information for all Vservers:
  • Vserver name
  • Node name
  • List of connected Vscan servers
  • Connected count
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-servers <IP Address>,…​] - List of Connected Vscan Servers
If you specify this parameter, the command displays information only about the Vservers that have the specified server or servers.
[-connection-count <integer>] - Number of Connected Vscan Servers Serving the Vserver
If you specify this parameter, the command displays information only about the Vservers that have the specified connection count.
The following example displays connection-status summary for all Vservers.
cluster1::> vserver vscan connection-status show
                                       Connected Connected
Vserver         Node                Server-Count Servers
vs1             Cluster-01                     2 1.1.1.1, 2.2.2.2
vs2             Cluster-01                     0 -
2 entries were displayed.
