system node coredump reports show
Display a list of application core reports
The system node coredump reports show command displays basic information about application core reports, such as the report name and time of the panic that triggered the application core dump. You can specify optional parameters to display information that matches only those parameters. For example, to display the list of reports in the local node, run the command with -node local.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node That Owns the Coredump
Selects information about all the reports on the specified node. If you specify both this parameter and the -reportname parameter, the command displays detailed information about the specified report.
[-reportname <text>] - Report Name
Selects information about the reports that match the specified name. If you specify both this parameter and the -node parameter, the command displays detailed information about the specified report.
[-panic-node <text>] - Node That Generated Core
Selects information about the reports that were generated by the specified node.
[-panic-systemid <integer>] - System ID of Node That Generated Core
Selects information about the reports that were generated by thenode with the specified system ID.
[-version <text>] - Data ONTAP Version of Core
Selects information about the reports that match the specified version.
[-panic-time <MM/DD/YYYY HH:MM:SS>] - Time of Panic That Generated Core
Selects information about the reports that were generated by a panic at the specified time. Specify time in the format of MM/DD/YYYY HH:MM:SS [- HH:MM]_`` . You can use ``_[- HH:MM] to specify the time range within which all core files triggered by a panic are displayed. [+- HH:MM] is relative to UTC.
[-panic-string <text>] - Panic String
Selects information about the reports that match the specified panic string.
The following example displays information about the reports:
cluster1::> system node coredump reports show
Node     Report Name                                    Panic Time
node0  notifyd.1894.80335005.2011-03-25.09_59_43.ucore.report  3/25/2011 09:59:43
