statistics cache flash-pool show
Flash pool throughput metrics
This command continuously displays performance data for flash pool caches at a regular interval. The command output displays data in the following columns:
Aggregate - aggregate name.
Vserver - vserver name.
Volume - volume name.
Read Hit - percent of IOs serviced from a cache level.
Write Hit - percent of IOs serviced from a cache level.
Cache Used - percent of cache used.
Read Blocks - read blocks.
Write Blocks - write blocks.
Rejects - cache rejects.
[-aggregate <text>]
- Aggregate-
Selects the aggregate for which you want to display performance data.
[-vserver <vserver name>]
- Vserver-
Selects the vserver for which you want to display performance data.
[-volume <text>]
- Volume-
Selects the volume for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies the maximum number of flash pools to display. The default setting is 25.
The following example displays flash pool statistics:
cluster1::> statistics cache flash-pool show cluster1 : 12/31/2013 16:00:04 Read Write Cache Hit Hit Used Read Write Aggregate Vserver Volume (%) (%) (%) Blocks Blocks Rejects ----------- -------- ------- ---- ----- ----------- ------- ------- ------- aggr1 - -total- 0 0 0 0 0 0 aggr2 vs1 vol1 0 0 0 0 0 0 [...]
