volume encryption secure-purge abort
Abort secure deletion of trash in existing volume
The volume encryption secure-purge abort command aborts the secure purge operation on a volume.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver on which the volume is located.
-volume <volume name> - Volume
This parameter specifies the name of the volume being encrypted.
