network interface failover-groups modify
PDF of this doc site
Creating your file...
Modify a failover group
The network interface failover-groups modify
command enables you modify the list of network ports, interface groups, or VLANs belonging to an existing logical interface failover group. The specified list will overwrite the existing list of network ports, interface groups, and VLANs currently belonging to the logical interface failover group.
-vserver <vserver>
- Vserver Name-
Use this parameter to specify the name of the Vserver(s) from which this failover group is accessible.
-failover-group <text>
- Failover Group Name-
Use this parameter to specify the failover group that you want to modify.
[-targets [node>:<port],…]
- Failover Targets-
Use this parameter to specify the network ports, interface groups, or VLANs you wish to now belong to the failover group.
This example shows the failover group "clyde" being modified to now contain the specified network ports.
cluster1::> network interface failover-group modify -vserver vs1 -failover-group clyde -targets xena1:e0c, xena1:e0d-100, xena2:a0a
