ONTAP commands
system ha interconnect ood status show
Display the high-availability interconnect device out-of-order delivery (OOD) information
The system ha interconnect ood status show command displays configuration information of the out-of-order delivery-capable high-availability interconnect devices. This command is supported only on FAS2500 series nodes in the cluster.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display all the fields from the specified node in the cluster.
[-is-ood-enabled {true|false}] - Is OOD Enabled (privilege: advanced)
Selects the nodes that match this parameter value.
[-is-coalescing-enabled {true|false}] - Is Coalescing Enabled (privilege: advanced)
The following example displays the HA interconnect device out-of-order delivery configuration information on FAS2500 series nodes in the cluster.
cluster1::*> system ha interconnect ood status show
Node: ic-f2554-03
              NIC Used: 0
        Is OOD Enabled: true
 Is Coalescing Enabled: true
Node: ic-f2554-04
              NIC Used: 0
2 entries were displayed.
