The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume quota policy rename
PDF of this doc site
Creating your file...
Your file is ready
Rename a quota policy
This command renames a quota policy. You must enter the following information to rename a quota policy:
Vserver name
Policy name
New policy name
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver containing the quota policy you want to rename.
-policy-name <text>
- Policy Name-
This parameter specifies the name of the quota policy you are renaming.
-new-policy-name <text>
- New Policy Name-
This parameter specifies the new name of the quota policy. The new name cannot be more than 32 characters long.
The following example renames a quota policy named quota_policy_0 on Vserver vs0. The policy's new name is quota_policy_1.
cluster1::> volume quota policy rename -vserver vs0 -policy-name quota_policy_0 -new-policy-name quota_policy_1
