ONTAP 9.6 commands
volume efficiency stop
Stop efficiency operation on a volume
Use the volume efficiency stop command to stop an efficiency operation.
-vserver <vserver name> - Vserver Name
This specifies the Vserver on which the volume is located.
{ -volume <volume name> - Volume Name
This specifies the name of the volume on which efficiency operation needs to be stopped.
| -path </vol/volume> - Volume Path }
This specifies the volume path on which efficiency operation needs to be stopped.
[-a, -all <true>] - Stop All Operations
This specifies both active and queued efficiency operations to be aborted.
The following examples stop efficiency on a volume.
cluster1::> volume efficiency stop -vserver vs1 -volume vol1
cluster1::> volume efficiency stop -vserver vs1 -volume vol1 -all
