storage failover hwassist show
Display hardware-assisted storage failover status
The storage failover hwassist show command displays information about the hardware-assisted storage failover status on each node. By default, the command displays the following information:
  • Node name.
  • Partner node name.
  • Whether hardware-assisted failover is enabled.
  • IP address on which the local node receives hardware-assisted failover alerts.
  • Port on which the local node receives hardware-assisted failover alerts.
  • Hardware-assisted failover status.
  • If the monitor is inactive, the reason it is inactive.
  • If the monitor is inactive, the corrective action to make it active.
  • Status of keep-alive alerts on the local node.
Hardware-assisted failover establishes a notification channel from each respective node’s service processor to the other (HA partner) node. If a node becomes unresponsive, its service processor notifies the HA partner of this condition, accelerating storage failover. By default, hwassist is enabled and configured automatically to use each node’s node-mgmt LIF. To modify or show the hardware-assisted storage failover configuration, use the storage failover modify and storage failover show commands.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you specify this parameter, the command displays information only about hwassist on the specified nodes.
[-partner-name {<nodename>|local}] - Name of the Partner Node
If you specify this parameter, the command displays information only about hwassist on nodes with the specified partner node.
[-enabled {true|false}] - Local Hardware Assist Enabled
If you specify this parameter, the command displays information only about hwassist on nodes with the specified enabled state.
[-local-status <text>] - Local Node’s Hwassist Status
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local status (active or inactive ).
[-local-ip <text>] - IP Address on Which Local Node is Listening
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local IP address.
[-local-port <integer>] - Port on Which Local Node is Listening
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local UDP port.
[-local-inactive <text>] - Local Node’s Hwassist Inactive Status Reason
If you specify this parameter, the command displays information only about hwassist on nodes with the specified inactive reason.
[-local-action <text>] - Corrective Action on Local Node
If you specify this parameter, the command displays information only about hwassist on nodes with the specified corrective action.
The following example displays the hardware-assisted failover information for node cluster1-01 and its HA partner node cluster1-02:
cluster1::> storage failover hwassist show
    Node
    cluster1-01
                                 Partner: cluster1-02
                        Hwassist Enabled: true
                             Hwassist IP: 10.225.248.19
                           Hwassist Port: 4444
                          Monitor Status: active
                         Inactive Reason: -
                       Corrective Action: -
                       Keep-Alive Status: healthy
    cluster1-02
                                 Partner: cluster1-01
                             Hwassist IP: 10.225.248.21
                           Hwassist Port: 4444
                         Inactive Reason: -
