storage failover hwassist show
Display hardware-assisted storage failover status
The storage failover hwassist show
command displays information about the hardware-assisted storage failover status on each node. By default, the command displays the following information:
Node name.
Partner node name.
Whether hardware-assisted failover is enabled.
IP address on which the local node receives hardware-assisted failover alerts.
Port on which the local node receives hardware-assisted failover alerts.
Hardware-assisted failover status.
If the monitor is inactive, the reason it is inactive.
If the monitor is inactive, the corrective action to make it active.
Status of keep-alive alerts on the local node.
Hardware-assisted failover establishes a notification channel from each respective node's service processor to the other (HA partner) node. If a node becomes unresponsive, its service processor notifies the HA partner of this condition, accelerating storage failover. By default, hwassist is enabled and configured automatically to use each node's node-mgmt LIF. To modify or show the hardware-assisted storage failover configuration, use the storage failover modify and storage failover show commands.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about hwassist on the specified nodes.
[-partner-name {<nodename>|local}]
- Name of the Partner Node-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified partner node.
[-enabled {true|false}]
- Local Hardware Assist Enabled-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified enabled state.
[-local-status <text>]
- Local Node's Hwassist Status-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local status (
active
orinactive
). [-local-ip <text>]
- IP Address on Which Local Node is Listening-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local IP address.
[-local-port <integer>]
- Port on Which Local Node is Listening-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local UDP port.
[-local-inactive <text>]
- Local Node's Hwassist Inactive Status Reason-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified inactive reason.
[-local-action <text>]
- Corrective Action on Local Node-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified corrective action.
The following example displays the hardware-assisted failover information for node cluster1-01 and its HA partner node cluster1-02:
cluster1::> storage failover hwassist show Node ----------------- cluster1-01 Partner: cluster1-02 Hwassist Enabled: true Hwassist IP: 10.225.248.19 Hwassist Port: 4444 Monitor Status: active Inactive Reason: - Corrective Action: - Keep-Alive Status: healthy cluster1-02 Partner: cluster1-01 Hwassist Enabled: true Hwassist IP: 10.225.248.21 Hwassist Port: 4444 Monitor Status: active Inactive Reason: - Corrective Action: - Keep-Alive Status: healthy
