storage failover hwassist show
Display hardware-assisted storage failover status
The storage failover hwassist show command displays information about the hardware-assisted storage failover status on each node. By default, the command displays the following information:
Node name.
Partner node name.
Whether hardware-assisted failover is enabled.
IP address on which the local node receives hardware-assisted failover alerts.
Port on which the local node receives hardware-assisted failover alerts.
Hardware-assisted failover status.
If the monitor is inactive, the reason it is inactive.
If the monitor is inactive, the corrective action to make it active.
Status of keep-alive alerts on the local node.
Hardware-assisted failover establishes a notification channel from each respective node's service processor to the other (HA partner) node. If a node becomes unresponsive, its service processor notifies the HA partner of this condition, accelerating storage failover. By default, hwassist is enabled and configured automatically to use each node's node-mgmt LIF. To modify or show the hardware-assisted storage failover configuration, use the storage failover modify and storage failover show commands.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays information only about hwassist on the specified nodes.
[-partner-name {<nodename>|local}]- Name of the Partner Node-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified partner node.
[-enabled {true|false}]- Local Hardware Assist Enabled-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified enabled state.
[-local-status <text>]- Local Node's Hwassist Status-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local status (
activeorinactive). [-local-ip <text>]- IP Address on Which Local Node is Listening-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local IP address.
[-local-port <integer>]- Port on Which Local Node is Listening-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified local UDP port.
[-local-inactive <text>]- Local Node's Hwassist Inactive Status Reason-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified inactive reason.
[-local-action <text>]- Corrective Action on Local Node-
If you specify this parameter, the command displays information only about hwassist on nodes with the specified corrective action.
The following example displays the hardware-assisted failover information for node cluster1-01 and its HA partner node cluster1-02:
cluster1::> storage failover hwassist show
Node
cluster1-01
Partner: cluster1-02
Hwassist Enabled: true
Hwassist IP: 10.225.248.19
Hwassist Port: 4444
Monitor Status: active
Inactive Reason: -
Corrective Action: -
Keep-Alive Status: healthy
cluster1-02
Partner: cluster1-01
Hwassist IP: 10.225.248.21
Hwassist Port: 4444
Inactive Reason: -
