system service-processor ssh add-allowed-addresses
Add IP addresses to the list that is allowed to access the Service Processor
The system service-processor ssh add-allowed-addresses
command grants IP addresses access to the Service Processor.
-allowed-addresses <IP Address/Mask>,…
- Public IP Addresses-
Use this parameter to specify one or more IP addresses with corresponding netmasks. The value should be specified in the format of address/netmask, for example, 10.98.150.10/24, fd20:8b1e:b255:c09b::/64. Use commas to separate multiple address/netmask pairs. If "0.0.0.0/0, ::/0" is specified in the parameter, any IP address is allowed to access the Service Processor.
The following examples grant the specified IP addresses access to the Service Processor and display the list of public IP addresses that are allowed to access the Service Processor.
cluster1::> system service-processor ssh show Allowed Addresses: 0.0.0.0/0, ::/0 cluster1::> system service-processor ssh add-allowed-addresses -allowed-addresses 192.168.1.202/24, 192.168.10.201/24 Warning: The default "allow all" setting (0.0.0.0/0, ::/0) will be replaced with your changes. Do you want to continue? {y|n}: y cluster1::> system service-processor ssh show Allowed Addresses: 192.168.1.202/24, 192.168.10.201/24 The following example enables all IP addresses to access the Service Processor. cluster1::> system service-processor ssh add-allowed-addresses -allowed-addresses 0.0.0.0/0, ::/0 cluster1::> system service-processor ssh show Allowed Addresses: 0.0.0.0/0, ::/0 cluster1::>
