system node show-discovered
Display all nodes discovered on the local network
The system node show-discovered command displays information about all the detectable nodes on the local cluster network. This includes both nodes in a cluster and nodes that do not belong to a cluster. You can filter the output to show only nodes that do not belong to a cluster or nodes that are in a cluster.
To see a list of values that are in use for a particular field, use the -fields parameter of this command with the list of field names you wish to view.
[-fields <fieldname>,…] -
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]} -
If the
-instanceparameter is specified, the command displays detailed information about each node. [-node <text>]- Node Name-
This parameter specifies the name of a node for which information is to be displayed. If this parameter is not specified, the command displays information about all discovered nodes.
 [-is-in-cluster {true|false}]- Is in a Cluster-
If this parameter is set to
false, the command lists only nodes that do not belong to a cluster. [-cluster-uuid <UUID>]- Cluster UUID-
Displays information about nodes belonging to the cluster that has the UUID you specify.
 [-cluster-name <text>]- Cluster Name-
Displays information about nodes belonging to the cluster that has the name you specify.
 [-serial-number <text>]- Node Serial Number-
Displays information about the node that has the serial number you specify.
 [-addresses <IP Address>,…]- Cluster IP Addresses-
Displays information about the node that has the cluster IP addresses you specify.
 [-netmask <IP Address>]- Cluster Address Mask-
Displays information about the nodes that have the netmask address you specify.
 [-nvramid <nvramid>]- Node NVRAM ID-
Displays information about the node that has the NVRAM ID you specify.
 [-partner-nvramid <nvramid>]- Partner NVRAM ID-
Displays information about the node that has an HA partner with the NVRAM ID you specify.
 [-model <text>]- Model-
Displays the nodes that have the specified model number.
 [-version <text>]- Software Version-
Displays the nodes that have the specified version of Data ONTAP.
The following example displays information about all discovered nodes in the cluster network:
cluster1::*> system node show-discovered Node Cluster Addresses NVRAM ID Partner NVRAM ------------- ------------- --------------- ----------- -------------- 4069114-60-0 - 169.254.232.178 4069114600 - 4069114-60-2 - 169.254.79.38 4069114602 - 4069114-60-3 - 169.254.195.76 4069114603 - cluster1-01 cluster1 169.254.140.39 4069114628 4069114629 cluster1-02 cluster1 169.254.138.137 4069114629 4069114628
