ONTAP commands
job schedule cron show
Show cron schedules
The job schedule cron show command displays information about cron schedules. A cron schedule runs a job at a specified time on specified days.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-cluster <Cluster name>] - Cluster
Selects the cron schedules that match this parameter value.
[-name <text>] - Name
[-month <cron_month>,…​] - Month
Selects the cron schedules that match this parameter value. Valid values are January , February , March , April , May , June , July , August , September , October , November , December , or all .
[-dayofweek <cron_dayofweek>,…​] - Day of Week
Selects the cron schedules that match this parameter value. Valid values include Sunday , Monday , Tuesday , Wednesday , Thursday , Friday , Saturday , or all .
[-day <cron_dayofmonth>,…​] - Day
Selects the cron schedules that match this parameter value. Valid values range from 1 to 31 .
[-hour <cron_hour>,…​] - Hour
[-minute <cron_minute>,…​] - Minute
Selects the cron schedules that match the minute or range of minutes that you specify.
[-description <text>] - Description
The following example displays information about all current cron schedules:
cluster1::> job schedule cron show
Cluster       Name        Description
cluster1
              5min        @:00,:05,:10,:15,:20,:25,:30,:35,:40,:45,:50,:55
              8hour       @2:15,10:15,18:15
              weekly      Sun@0:15
The following example displays information about the cron schedule named weekly:
cluster1::> job schedule cron show -name weekly -instance
Cluster: cluster1
      Month: -
Day of Week: Sunday
        Day: -
       Hour: 0
     Minute: 15
Description: Sun@0:15
