job schedule cron show
Show cron schedules
The job schedule cron show command displays information about cron schedules. A cron schedule runs a job at a specified time on specified days.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-cluster <Cluster name>]- Cluster
Selects the cron schedules that match this parameter value.
- [-vserver <vserver name>]- Vserver
Selects the cron schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
- [-name <text>]- Name
- [-month <cron_month>,…]- Month
Selects the cron schedules that match this parameter value. Valid values are January,February,March,April,May,June,July,August,September,October,November,December, orall.
- [-dayofweek <cron_dayofweek>,…]- Day of Week
Selects the cron schedules that match this parameter value. Valid values include Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday, orall.
- [-day <cron_dayofmonth>,…]- Day
Selects the cron schedules that match this parameter value. Valid values range from 1to31.
- [-hour <cron_hour>,…]- Hour
- [-minute <cron_minute>,…]- Minute
Selects the cron schedules that match the minute or range of minutes that you specify.
- [-description <text>]- Description
The following example displays information about all current cron schedules:
cluster1::> job schedule cron show
Cluster       Vserver     Name        Description
cluster1
              data_vs_1
                          5min        @:00,:05,:10,:15,:20,:25,:30,:35,:40,:45,:50,:55
                          8hour       @2:15,10:15,18:15
                          weekly      Sun@0:15
The following example displays information about the cron schedule named weekly:
cluster1::> job schedule cron show -name weekly -instance
Cluster: cluster1
    Vserver: data_vs_1
      Month: -
Day of Week: Sunday
        Day: -
       Hour: 0
     Minute: 15
Description: Sun@0:15
 PDFs
PDFs
