vserver fcp modify
Modify FCP service configuration
This command modifies an FCP service configuration on a Vserver.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver for the FCP service.
 [-target-name <text>]- Target Name (privilege: advanced)-
The FCP World Wide Node Name (WWNN) for the service. All FCP LIFs in the Vserver will share the specified WWNN. The format for a WWNN is "XX:XX:XX:XX:XX:XX:XX:XX" where X is a hexadecimal digit.
Unles the
forceoption is also provided, the specified WWNN must be within one of the following vendor registered namespaces:-
2X:XX:00:a0:98:XX:XX:XX
2X:XX:00:a0:b8:XX:XX:XX
2X:XX:d0:39:ea:XX:XX:XX
The user must ensure that the target name is not in use elsewhere outside the cluster. ONTAP cannot verify that the target name is unique outside the cluster if ONTAP did not generate the target name.
 [-status-admin {down|up}]- Administrative Status-
Specifies the administrative status of the FCP service of a Vserver. If you set this parameter to
up, the FCP service accepts login requests from FCP initiators. If you set this parameter todown, FCP initiators cannot log in. [-f, -force <true>]- Force (privilege: advanced)-
Allows you to specify a World Wide Node Name outside one of the known vendor registered namespaces.If you use this parameter without a value, it is set to
true, and the command does not error when the specified WWNN is outside one of the vendor registered namespaces.
cluster1::> vserver fcp modify -vserver vs_1 -status-admin down
Changes the administration status of the FCP service on Vserver vs_1 to down .
