system configuration backup delete
Delete a configuration backup
The system configuration backup delete
command deletes a saved configuration backup.
Use the system configuration backup show command to display saved configuration backups.
-node {<nodename>|local}
- Node-
Use this parameter to specify the name of the source node where the configuration backup currently exists.
-backup <text>
- Backup Name-
Use this parameter to specify the name of the configuration backup file to delete.
The following example shows how to delete the configuration backup file node1.special.7z
from the node node1
cluster1::*> system configuration backup delete -node node1 -backup node1.special.7z
