storage array disk paths show
Display a list of LUNs on the given array
The storage array disk paths show command displays information about disks and array LUNs. Where it appears in the remainder of this document, "disk" may refer to either a disk or an array LUN. By default, the command displays the following information about all disks:
Disk Unique Identifier
Controller name
Initiator Port
LUN ID
Failover optimization type
The Use State of the LUN on this path
Target Port
Target IQN
TPGN
Port speeds
Kbytes/sec on Disk (Rolling Average)
Number IOPS per second on disk (Rolling Average)
To display detailed information about a single disk, use the -disk parameter.
[-fields <fieldname>,…] -
Displays the specified fields for all disks, in column style output.
[-switch ] -
Displays the switch port information for all disks, in column style output.
[-instance ]} -
Displays detailed disk information. If no disk path name is specified, this parameter displays the same detailed information for all disks as does the -disk parameter. If a disk path name is specified, then this parameter displays the same detailed information for the specified disks as does the -disk parameter.
[-uid <text>]- Disk Unique Identifier-
Selects the disks whose unique id matches this parameter value. A disk unique identifier has the form: `20000000:875D4C32:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 `
[-disk <disk path name>]- Disk Name-
Displays detailed information about the specified disks.
[-array-name <array name>]- Array Name-
Selects information about the LUNs presented by the specified storage array.
[-diskpathnames <disk path name>,…]- Path-Based Disk Names-
Selects information about disks that have all of the specified path names.
[-nodelist {<nodename>|local}]- Controller name-
Selects information about disks that are visible to all of the specified nodes .
[-initiator <text>,…]- Initiator Port-
Selects information about disks that are visible to the initiator specified. Disks that are not currently in use by that initiator are included.
[-lun <integer>,…]- LUN ID-
Selects information about the specified LUNs.
[-target-wwpn <text>,…]- Target Port-
Selects information about disks that are visible on target ports identified by their World Wide Port Name.
[-initiator-side-switch-port <text>,…]- Initiator Side Switch Port-
Selects information about disks visible to an initiator that is connected to the specified switch port.
[-lun-path-use-state <text>,…]- The Use State of the LUN on this path-
Selects information about LUNs reporting the specified in-use state.
[-tpgn <integer>,…]- Target Port Group Number-
Selects information about disks that belong to the specified Target Port Group Number.
[-port-speed <text>,…]- Port Speed-
Selects information about disks served by a Host Bus Adapter that is running at the specified port speed.
[-lun-io-kbps <integer>,…]- Kbytes/sec on Disk (Rolling Average)-
Selects information about the LUNs that have reached the specified I/O throughput.
[-lun-iops <integer>,…]- Number IOPS per second on disk (Rolling Average)-
Selects information about the LUNs that have reached the specified number of IOPs.
[-target-side-switch-port <text>,…]- Target Side Switch Port-
Selects information about disks that are visible on target ports identified by the switch port to which they are connected.
[-target-port-access-state <text>,…]- Failover optimization type-
Selects information about disks visible on target ports that have the specified access state.
[-initiator-io-kbps <integer>,…]- Kbytes of I/O per second on Initiator (Rolling Average)-
Selects information about disks visible to an initiator that has executed I/O at the specified throughput.
[-initiator-iops <integer>,…]- Number of IOPS on Initiator (Rolling Average)-
Selects information about disks visible to an initiator that has executed the specified number of IOPs.
[-target-io-kbps <integer>,…]- Kbytes of I/O per second to Target (Rolling Average)-
Selects information about disks visible on target ports that have reached the specified I/O throughput.
[-target-iops <integer>,…]- Number of IOPS to Target (Rolling Average)-
Selects information about disks visible on target ports that have performed the specified number of IOPs.
[-path-link-errors <integer>,…]- Link Error count on path-
Selects information about disks with paths that have incurred the specified number of FC link errors.
[-path-io-kbps <integer>,…]- Kbytes of I/O per second on Path (Rolling Average)-
Selects information about disk with paths that have reached the specified I/O throughput.
[-path-iops <integer>,…]- Number of IOPS on Path (Rolling Average)-
Selects information about disks on those paths that have reached the specified number of IOPs.
[-path-quality <integer>,…]- Percentage of weighted error threshold-
Selects information about disks on paths that have incurred the specified number of errors. The value displayed is a measure of the health of a path expressed as a percentage of an error threshold. Once a path has reached or surpassed the error threshold, another path will be selected for I/O transfer, if there is one available.
[-path-lun-in-use-count <integer>,…]- Number of LUNs in the in-use state on this path-
Selects information about disks with paths that have the specified in-use-count.
[-initiator-lun-in-use-count <integer>,…]- Number of LUNs in the in-use state on this initiator-
Selects information about disks with a path through an initiator that has the specified in-use-count.
[-target-lun-in-use-count <integer>,…]- Number of LUNs in the in-use state on this target-
Selects information about disks with a path through a target port that has the specified in-use-count.
[-preferred-target-port {true|false}]- Whether or not target port group is preferred-
Selects information about disks that match the specified parameter value indicating whether the backing storage is ALUA (Assymetric Logical Unit Access) capable and has specified the array target port on this path to be a preferred target port for I/O.
[-vmdisk-device-id <integer>,…]- Virtual disk device ID-
Selects information about disks that have the specified virtual disk device ID.
[-host-adapter <text>]- Primary Path Host Adapter-
Selects information about disks that are currently using the specified Host Bus Adapter.
[-primary-port <text>]- Primary Path Disk Port-
Selects information about disks that use the specified primary port.
[-secondary-name <disk path name>]- Secondary Path Name-
Selects information about disks that use the specified secondary path name, for multipath configuration.
[-secondary-port <text>]- Secondary Path Disk Port-
Selects information about disks that use the specified secondary port.
The following example displays information about all disks:
cluster1::> storage array disk paths show
Disk Name: 1.0.20
UID: 5000C500:0979E09F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000
LUN Link Disk I/O
Controller Initiator ID Acc Use Target Port TPGN Speed (KB/s) IOPS
node2 3a 0 AO INU 5000c5000979e09d 80 9 Gb/S 0 0
node2 3c 0 AO RDY 5000c5000979e09e 12 9 Gb/S 0 0
node1 3a 0 AO RDY 5000c5000979e09e 12 9 Gb/S 0 0
node1 3c 0 AO INU 5000c5000979e09d 80 9 Gb/S 0 0
Disk Name: 1.0.22
UID: 5000C500:0979E3C3:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000
LUN Link Disk I/O
node2 3a 0 AO INU 5000c5000979e3c1 83 9 Gb/S 0 0
node2 3c 0 AO RDY 5000c5000979e3c2 15 9 Gb/S 0 0
node1 3a 0 AO RDY 5000c5000979e3c2 15 9 Gb/S 0 0
node1 3c 0 AO INU 5000c5000979e3c1 83 9 Gb/S 0 0
Disk Name: 1.0.19
UID: 5000C500:0979E3F3:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000
LUN Link Disk I/O
node2 3a 0 AO RDY 5000c5000979e3f1 86 9 Gb/S 0 0
node2 3c 0 AO INU 5000c5000979e3f2 18 9 Gb/S 0 0
node1 3a 0 AO INU 5000c5000979e3f2 18 9 Gb/S 0 0
node1 3c 0 AO RDY 5000c5000979e3f1 86 9 Gb/S 0 0
Disk Name: 1.0.16
UID: 5000C500:0979EBEB:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000
LUN Link Disk I/O
node2 3a 0 AO INU 5000c5000979ebe9 71 9 Gb/S 283 3
node2 3c 0 AO RDY 5000c5000979ebea 3 9 Gb/S 0 0
node1 3a 0 AO RDY 5000c5000979ebea 3 9 Gb/S 0 0
node1 3c 0 AO INU 5000c5000979ebe9 71 9 Gb/S 3 0
