The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
san config show
PDF of this doc site
Creating your file...
Your file is ready
Show SAN configuration options for the cluster
The command displays cluster SAN configuration options.
The following example displays the cluster SAN configuration.
cluster1::> san config show All SAN Array: true
