lun mapping delete
Unmap a LUN from an initiator group
This command unmaps a LUN from an initiator group. After you use this command, the LUN is not visible to any of the initiators in the initiator group.
-vserver <Vserver Name>- Vserver Name-
Selects the LUN maps for the Vserver that matches the parameter value.
-path <path>- LUN Path -
Specifies the path of the LUN you want to unmap. Examples of correct LUN paths are
/vol/vol1/lun1and/vol/vol1/qtree1/lun1. - |
-volume <volume name>- Volume Name -
Specifies the volume of the LUN you want to unmap.
-qtree <qtree name>- Qtree Name-
Specifies the qtree of the LUN you want to unmap.
-lun <text>- LUN Name }-
Specifies the name of the LUN you want to unmap.
-g, -igroup <text>- Igroup Name-
Specifies the initiator group that you want to unmap the LUN from.
cluster1::> lun mapping delete -vserver vs1 -path /vol/vol1/lun1 -igroup ig1
Unmaps LUN at path /vol/vol1/lun1 from the initiator group ig1 on Vserver vs1.
