ONTAP 9.9.1 commands
network ndp neighbor show
Display static NDP neighbor entries
The network ndp neighbor show command displays a group of static Neighbor Discovery Protocol (NDP) neighbors within one or more Vservers. You can view static NDP neighbors within specified Vservers, neighbors with specified IPv6 address, and neighbors with specified MAC address.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name (privilege: advanced)
Displays the static NDP neighbors that have the specified Vserver as their origin.
[-neighbor <IP Address>] - Neighbor Address (privilege: advanced)
Displays the static NDP neighbors that have the specified IPv6 address.
[-mac-address <MAC Address>] - MAC Address (privilege: advanced)
Displays the static NDP neighbors that have the specified MAC address.
The following example displays all of the static NDP neighbors configured on Vserver vs0.
cluster1::*> network ndp neighbor show -vserver vs0
Vserver            Neighbor                 MAC Address
vs0
                   10:10::10                04:04:04:04:04:04
                   20:20::20                01:01:01:01:01:01
2 entries were displayed.
