volume prepare-for-revert
Preparing the volume for revert
The volume prepare-for-revert
command prepares volumes to be reverted to the previous version of ONTAP.
[-node {<nodename>|local}]
- Node Name (privilege: advanced)-
This specifies the name of the node in which all the volumes will be prepared for revert. If unspecified, the command will execute on the local node.
The following example prepares all volumes on node node1 to be reverted.
cluster1::*> volume prepare-for-revert -node node1
