vserver cifs domain discovered-servers discovery-mode show
Display Server Discovery Mode
The vserver cifs domain discovered-servers discovery-mode show command displays information about the discovery mode servers for the CIFS domains of one or more Vservers.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver (privilege: advanced)-
If you use this parameter, the command only displays discovery mode for the specified Vserver.
[-mode {all|site|none}]- Server Discovery Mode (privilege: advanced)-
If you use this parameter, the command only displays Vservers with the specified mode.
The following example shows the server discovery mode for all Vservers.
cluster1::> vserver cifs domain discovered-servers discovery-mode show Vserver Mode --------------- ---------- vs1 all vs2 site vs3 none 3 entries were displayed.
