ONTAP commands
vserver cifs domain discovered-servers discovery-mode show
Display Server Discovery Mode
The vserver cifs domain discovered-servers discovery-mode show command displays information about the discovery mode for domain controllers(DCs) of one or more Vservers.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <vserver name>] - Vserver (privilege: advanced)
If you use this parameter, the command only displays discovery mode for the specified Vserver.
[-mode {all|site|none}] - Server Discovery Mode (privilege: advanced)
If you use this parameter, the command only displays Vservers with the specified mode.
The following example shows the server discovery mode for all Vservers.
cluster1::*> vserver cifs domain discovered-servers discovery-mode show
Vserver         Mode
vs1             all
vs2             site
vs3             none
3 entries were displayed.
