ONTAP commands
volume clone split show
Show the status of FlexClone split operations in-progress
The volume clone split show command displays the progress information of all the active FlexClone volume splitting jobs. This command is only supported for flexible volumes. By default, this command displays the following information:
  • Vserver name
  • FlexClone volume name
  • Percentage of blocks processed
  • Total number of blocks scanned for clone splitting
  • Total number of blocks updated for clone splitting
If the -instance option is also specified, detailed information about all splitting jobs is displayed.
{ [-fields <fieldname>,…​]
This specifies the fields to be displayed, for all the ongoing FlexClone splitting jobs.
| [-instance ] }
This specifies the command to display detailed information about the ongoing FlexClone volume splitting jobs.
[-vserver <vserver name>] - Vserver Name
Selects information about the ongoing FlexClone volume splitting jobs for all FlexClone volumes on this Vserver.
[-flexclone <volume name>] - FlexClone Volume
Selects information about ongoing FlexClone volume splitting jobs for this FlexClone volume.
[-block-percentage-complete <integer>] - Percentage Complete
Selects information about all the ongoing FlexClone splitting jobs that have the specified percentage of Block processing completed.
[-blocks-scanned <integer>] - Blocks Scanned
Selects information about all the ongoing FlexClone splitting jobs that have the specified number of blocks scanned.
[-blocks-updated <integer>] - Blocks Updated
Selects information about all the ongoing FlexClone splitting jobs that have the specified number of blocks updated.
The following example displays information about all the ongoing FlexClone splitting jobs in the cluster.
cluster1::> volume clone split show
  (volume clone split show)
                                Blocks
Vserver   FlexClone       Scanned  Updated     % Complete
vs1       fc_vol_1          229        2             0
The following example displays information about FlexClone volume fc_vol_2 residing on Vserver vs0 .
cluster1::> volume clone split show -vserver vs0 -flexclone fc_vol_2 -instance
       Vserver Name: vs0
   FlexClone Volume: fc_vol_2
Percentage Complete: 0
     Blocks Scanned: 229
     Blocks Updated: 2
