ONTAP commands
system script show
Display saved CLI session logs
The system script show command displays information about files that contain records of CLI sessions.
For security reasons, the command normally displays only the script files created by the logged in user. Administrative users can display all log files using the -user parameter.
{ [-fields <fieldname>,…​]
| [-user ]
Use this parameter to display all script files created by all users, along with the username associated with each file.
| [-instance ] }
[-username <text>] - Log Owner Username
Use this parameter to display information only about files saved by the user you specify. The default username is that of the logged in user.
[-filename <text>] - Log Filename
Use this parameter to display information only about files that have the file name you specify.
[-size-limit {<integer>[KB|MB|GB|TB|PB]}] - Logfile Size Limit
Use this parameter to display information only about files that have the size limit you specify.
[-state <State of CLI session log>] - Current State
Use this parameter to display information only about files that have the state you specify. Valid values for this parameter are open-and-logging , file-full , and file-closed .
[-size {<integer>[KB|MB|GB|TB|PB]}] - Current Logfile Size
Use this parameter to display information only about files that are the size you specify.
[-mtime <MM/DD/YYYY HH:MM:SS>] - Last Modification Time
Use this parameter to display information only about files that were last modified at the date and time you specify.
[-this-session {yes|no}] - Session is Logging
Use this parameter with the value yes to display information only about files that are recording the current CLI session. Use this parameter with the value no to display information only about files that are not recording the current CLI session.
The following example displays typical system script information.
cluster1::> system script show
                    This
FileName            Sess State            Size    Last Mod Date
sessionlog1         no   file-closed      435B    12/2/2008 10:51:12
sessionlog2         yes  open-and-logging 193B    12/2/2008 10:51:29
2 entries were displayed.
