snaplock legal-hold dump-files
PDF of this doc site
Creating your file...
Dump list of files under legal-hold to specified output path.
The snaplock legal-hold dump-files
is used to dump the list of files under legal-hold for a given vserver, volume and litigation to an auto-generated file in the user specified path. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver for which the list of files under legal-hold is to be dumped.
-litigation-name <text>
- Litigation Name-
Specifies the name of the litigation for which the list of files under legal-hold is to be dumped.
-volume <volume name>
- Volume Name-
Specifies the name of the SnapLock compliance volume for which the list of files under legal-hold is to be dumped.
-output-volume <volume name>
- Output Volume Name-
Specifies the name of the output volume containing the output directory path where the list of files under legal-hold is to be dumped. The output volume must be a regular read-write volume.
-output-directory-path <text>
- Path Relative to Output Volume Root-
Specifies the output directory path relative to the output volume root, where the list of files under legal-hold is to be dumped. The output directory path should be of the form "/directory-path". If output needs to be dumped on the volume root, specify the path as "/".
The following example starts a legal-hold dump-files operation:
vs1::> snaplock legal-hold dump-files -volume vol1_slc -litigation-name lit1 -output-volume vol1 -output-directory-path /d1 SnapLock legal-hold dump-files operation is queued. Run "snaplock legal-hold show -operation-id 16842754 -instance" to view the operation status. vs1::>
