ONTAP commands
network port vip delete
Delete a VIP port
The network port vip delete command deletes a VIP port.
-node {<nodename>|local} - Node
The node associated with the VIP port to be deleted.
-port <netport> - Network Port
The name of the VIP port to be deleted.
This example shows how to delete VIP Port v0a on node1.
cluster1::> network port vip delete -node node1 -port v0a
