vserver peer modify
Modify a Vserver peer relationship
The vserver peer modify command modifies applications of the Vserver peer relationship.
-vserver <vserver> - Vserver Name
Specifies name of the local Vserver for which you want to modify applications of the Vserver peer relationship.
-peer-vserver <vserver> - Peer Vserver Name
Specifies name of the peer Vserver for which you want to modify applications of the Vserver peer relationship.
-applications {snapmirror|file-copy|lun-copy|flexcache} - Peering Applications
Specifies the Vserver peer applications.
The following example illustrates how to modify applications that are part of the peer relationship between the Vservers lvs1.example.com residing on cluster1 , and pvs1.example.com residing on cluster2 .
cluster1::> vserver peer modify -vserver lvs1.example.com -peer-vserver pvs1.example.com -applications snapmirror
