network connections active show
Show the active connections in this cluster
The network connections active show command displays information about active network connections.
The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system. |
[-fields <fieldname>,…] -
If you specify the
[-print-ip-addresses ] -
Print IP addresses for remote hosts — do not attempt to resolve the addresses to a hostname.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the connections that match this parameter value.
 [-cid <Cid>]- Connection ID-
 [-vserver <vserver>]- Vserver-
 [-lif-name <lif-name>]- Logical Interface Name-
 [-local-address <IP Address>]- Local IP address-
 [-local-port <integer>]- Local Port-
 [-remote-ip <InetAddress>]- Remote IP Address-
 [-remote-host <Remote IP>]- Remote Host-
 [-remote-port <integer>]- Remote Port-
 [-proto {UDP|TCP}]- Protocol-
Selects the connections that match this parameter value. Possible values are tcp (TCP), udp (UDP), and NA (not applicable).
 [-lifid <integer>]- Logical Interface ID-
 [-service <protocol service>]- Protocol Service-
Selects the connections that match this parameter value. Possible values include: nfs, iscsi, and loopback.
 [-lru {yes|no}]- Least Recently Used-
 [-blocks-lb {true|false}]- Connection Blocks Load Balance Migrate-
Selects the logical interfaces that are blocked (true) or not blocked (false) from migrating due to an active client connection.
The following example displays information about active network connections for the node named node0:
cluster1::> network connections active show node -node0 Vserver Interface Remote Name Name:Local Port IP Address:Port Protocol/Service ------- ---------------- ----------------- ---------------- node0 cluslif1:7070 192.0.2.253:48621 UDP/rclopcp node0 cluslif1:7070 192.0.2.253:48622 UDP/rclopcp node0 cluslif2:7070 192.0.2.252:48644 UDP/rclopcp node0 cluslif2:7070 192.0.2.250:48646 UDP/rclopcp node0 cluslif1:7070 192.0.2.245:48621 UDP/rclopcp node0 cluslif1:7070 192.0.2.245:48622 UDP/rclopcp node0 cluslif2:7070 192.0.2.251:48644 UDP/rclopcp node0 cluslif2:7070 192.0.2.251:48646 UDP/rclopcp node0 cluslif1:7070 192.0.2.248:48621 UDP/rclopcp node0 cluslif1:7070 192.0.2.246:48622 UDP/rclopcp node0 cluslif2:7070 192.0.2.252:48644 UDP/rclopcp node0 cluslif2:7070 192.0.2.250:48646 UDP/rclopcp node0 cluslif1:7070 192.0.2.254:48621 UDP/rclopcp node0 cluslif1:7070 192.0.2.253:48622 UDP/rclopcp [...]
