ONTAP commands
network connections active show
Show the active connections in this cluster
The network connections active show command displays information about active network connections.
Note The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system.
{ [-fields <fieldname>,…​]
| [-print-ip-addresses ]
Print IP addresses for remote hosts — do not attempt to resolve the addresses to a hostname.
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the connections that match this parameter value.
[-cid <Cid>] - Connection ID
[-vserver <vserver>] - Vserver
[-lif-name <lif-name>] - Logical Interface Name
[-local-address <IP Address>] - Local IP address
[-local-port <integer>] - Local Port
[-remote-ip <InetAddress>] - Remote IP Address
[-remote-host <Remote IP>] - Remote Host
[-remote-port <integer>] - Remote Port
[-proto {UDP|TCP|TLS}] - Protocol
Selects the connections that match this parameter value. Possible values are tcp (TCP), udp (UDP), and NA (not applicable).
[-lifid <integer>] - Logical Interface ID
[-service <protocol service>] - Protocol Service
Selects the connections that match this parameter value. Possible values include: nfs, iscsi, and loopback.
[-lru {yes|no}] - Least Recently Used
[-blocks-lb {true|false}] - Connection Blocks Load Balance Migrate
Selects the logical interfaces that are blocked (true) or not blocked (false) from migrating due to an active client connection.
The following example displays information about active network connections for the node named node0:
cluster1::> network connections active show node -node0
Vserver Interface        Remote
Name    Name:Local Port  IP Address:Port   Protocol/Service
node0   cluslif1:7070    192.0.2.253:48621 UDP/rclopcp
node0   cluslif1:7070    192.0.2.253:48622 UDP/rclopcp
node0   cluslif2:7070    192.0.2.252:48644 UDP/rclopcp
node0   cluslif2:7070    192.0.2.250:48646 UDP/rclopcp
node0   cluslif1:7070    192.0.2.245:48621 UDP/rclopcp
node0   cluslif1:7070    192.0.2.245:48622 UDP/rclopcp
node0   cluslif2:7070    192.0.2.251:48644 UDP/rclopcp
node0   cluslif2:7070    192.0.2.251:48646 UDP/rclopcp
node0   cluslif1:7070    192.0.2.248:48621 UDP/rclopcp
node0   cluslif1:7070    192.0.2.246:48622 UDP/rclopcp
node0   cluslif1:7070    192.0.2.254:48621 UDP/rclopcp
