ONTAP 9.9.1 commands
system controller slot module replace
Power off a module on the controller for replacement
The system controller slot module replace command powers off a module on the controller for replacement.
-node {<nodename>|local} - Node
Selects the PCIe modules that are present in the specified node.
-slot <text> - Slot Number
Selects the PCIe modules present in the specified slot or slot-subslot combination.
The following example powers off a module in the local node:
p2i030::> system controller slot module replace -node local -slot 1
Warning: IO_CARRIER_NIANTIC_NIC module in slot 1 of node p2i030 will be powered
          off for replacement.
Do you want to continue? {y|n}: y
The module has been successfully powered off. It can now be safely replaced. After the replacement module is inserted, use the "system controller slot module insert" command to place the module into service.
p2i030::>
