vserver iscsi stop
PDF of this doc site
Creating your file...
Your file is ready
Stops the iSCSI service
Stops the iSCSI service of a Vserver. This command shuts down all active iSCSI sessions and stops any new iSCSI sessions. You can also use vserver iscsi modify with "-status-admin down".
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver for the iSCSI service.
cluster1::> vserver iscsi stop -vserver vs_1
Stops the iSCSI service for Vserver vs_1.
