ONTAP commands
volume schedule-style prepare-to-downgrade
Disables volume schedule style feature and sets schedule style to default (create-time)
This command will disable the volume schedule style feature and set schedule style to default (create-time).
The following example prepares the schedule-style on all volumes for revert/downgrade.
cluster1::*> volume schedule-style prepare-to-downgrade
