network route show-lifs
Show the Logical Interfaces for each route entry
The network route show-lifs command displays the association of static routes and Logical Interfaces (LIFs) within one or more Vservers. You can view routes within specified Vservers, routes with specified destinations, and routes with specified gateways.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver Name-
Use this parameter to display only routes that have the specified Vserver as their origin.
 [-destination <IP Address/Mask>]- Destination/Mask-
Use this parameter to display only routes that have the specified IP address and subnet mask as their destination. The format for this value is: address, slash ("/"), mask. For example,
0.0.0.0/0is a valid value for the -destination parameter. [-gateway <IP Address>]- Gateway-
Use this parameter to display only routes that have the specified IP address as their gateway.
 [-lifs <lif-name>,…]- Logical Interfaces-
Use this parameter to display only the routes that are associated with the specified Logical Interfaces (LIFs).
 [-address-family {ipv4|ipv6|ipv6z}]- Address Family-
Use this parameter to display only the routes that belong to specified address family.
