network trace file delete
Delete a network trace file
The network trace file delete command deletes the network trace file from a matching node.
-node {<nodename>|local}- Node Name-
Use this parameter to delete the network trace file from a matching node.
-trace-file <text>- Trace File-
Use this parameter to specify the network trace file to be deleted.
The following example deletes the list of network trace files from node "node1" using wildcard pattern:
cluster1::> network trace file delete -node node1 -trace-file *
