vserver nvme namespace create
Create an NVMe namespace
The vserver nvme namespace create command creates a new NVMe namespace of a specific size. You must create NVMe namespaces at the root of a volume or qtree.
When you create an NVMe namespace, it is non-space reserved.
This command is not supported for FlexGroups or Vservers with Infinite Volumes. |
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
-path <path>- Namespace Path-
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths are
/vol/vol1/ns1and/vol/vol1/qtree1/ns1. -size {<integer>[KB|MB|GB|TB|PB]}- Size-
Specifies the size of the NVMe namespace in bytes. You can specify a multiplier suffix:
KB (1024 bytes)
MB (KB*KB bytes)
GB (KB*MB bytes)
TB (MB*MB bytes)
-ostype {vmware|windows|linux}- OS Type-
Specifies the operating system type of the NVMe namespace. The OS types are:
linux - the NVMe namespace stores Linux file system data.
vmware - the NVMe namespace stores VMware file system data.
windows - the NVMe namespace stores Windows file system data.
[-comment <text>]- Comment-
Contains a textual description of the NVMe namespace.
[-block-size {512|4KB}]- Block Size-
Specifies the block size of the NVMe namespace in bytes. Valid block sizes are
512(in Data ONTAP 9.6 and later) -
4096
cluster1::*> vserver nvme namespace create -vserver vs_1 -path /vol/nsvol/namespace1 -size 100g -ostype linux
Creates an NVMe namespace at path /vol/ns/vol/namespace1 on Vserver vs_1 .
