The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node image package show
PDF of this doc site
Creating your file...
Your file is ready
Display software package information
The package show command displays details of the software packages residing on the storage controller.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects which node's packages are displayed. The local node is the default if this parameter is omitted.
[-package <text>]
- Package File Name (privilege: advanced)-
This parameter specifies which package's information will be displayed.
cluster1::> system image package show Package Node Repository Package File Name ---- ---------- ----------------- node-01 mroot image.tgz 1 entries were displayed.
