system configuration backup upload
Upload a configuration backup
The system configuration backup upload command copies a configuration backup from a node in the cluster to a remote URL.
-node {<nodename>|local}- Node (privilege: advanced)-
Use this parameter to specify the name of the node from which the configuration backup is uploaded.
-backup <text>- Backup Name (privilege: advanced)-
Use this parameter to specify the file name of the configuration backup to upload.
-destination <text>- Destination URL (privilege: advanced)-
Use this parameter to specify the destination URL of the configuration backup.
The following example show how to upload the configuration backup file testconfig.7z from the node node2 to a remote URL.
cluster1::*> system configuration backup upload -node node2 -backup testconfig.7z -destination ftp://www.example.com/config/uploads/testconfig.7z
