The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system services ndmp password
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Change the NDMP password for the node
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp generate-password " command. |
The system services ndmp password
command is used to change the NDMP password for a node in the cluster.
-node {<nodename>|local}
- Node-
The specific node for which the password is to be changed.
The following example is used to change the NDMP password for the node named node1:
cluster1::> system services ndmp password -node node1 Please enter password: Confirm password:
