The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver audit disable
PDF of this doc site
Creating your file...
Your file is ready
Disable auditing
The vserver audit disable
command disables auditing for a Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for which auditing is to be disabled. The Vserver audit configuration must already exist.
The following example disables auditing for Vserver vs1.
cluster1::> vserver audit disable -vserver vs1
