ONTAP commands
storage failover hwassist test
Test the hwassist functionality
The ` storage failover hwassist test` command tests the Hardware Assist h/w connectivity between the two nodes in a HA pair. The test result can be one of the following.
  • Hardware Assist is not initialized.
  • HW assist is not supported.
  • Partner is throttling alerts.
  • Resource is busy.
  • Hardware Assist h/w returned an error.
  • No response from partner.Timed out.
  • Unexpected abort.
  • Partner has taken over.
  • Interconnect is down between nodes.
  • Partner is not booted up yet.
-node {<nodename>|local} - Node
This specifies the node from which a test alert is initiated.
The following command issues a test alert from the node cluster1-01:
cluster1::> storage failover hwassist test -node cluster1-01
Info: Operation successful.
