The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver vscan scanner-pool delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a scanner pool
The vserver vscan scanner-pool delete
command deletes a scanner pool.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver from which you want to delete a scanner pool.
-scanner-pool <Scanner pool>
- Scanner Pool-
This parameter specifies the name of the scanner-pool that you want to delete.
The following example deletes a scanner pool.
cluster1::> vserver vscan scanner-pool delete -vserver vs1 -scanner-pool test cluster1::> vserver vscan scanner-pool show -vserver vs1 -scanner-pool test There are no entries matching your query.
