The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network options cluster-health-notifications modify
PDF of this doc site
Creating your file...
Your file is ready
cluster health notification options
This command enables or disables cluster health notifications on the specified node.
-node {<nodename>|local}
- Node-
This parameter specifies the node for which the cluster health notification status will be modified.
[-enabled {true|false}]
- Cluster Health Notifications Enabled-
Setting this parameter to
true
enables cluster health notification. Setting it tofalse
disables cluster health notification.
The following example modifies the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications modify -node node1 -enabled true
