The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security session limit create
PDF of this doc site
Creating your file...
Your file is ready
Create default session limit
This command allows creation of a default management session limit that does not yet exist. The default limits can be overridden for specific values within each category by using advanced privilege level commands.
-interface {cli|ontapi|rest}
- Interface-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-category {application|location|request|user|vserver}
- Category-
The session type for this default limit. The following categories are supported: application, location, request, user, Vserver.
-max-active-limit <integer>
- Max-Active Limit-
The maximum number of concurrent sessions allowed for this interface and category.
The following example illustrates creating a default limit for management sessions using the same application.
cluster1::> security session limit create -interface ontapi -category application -max-active-limit 8
