The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network route delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a static route
The network route delete
command deletes a static route from a Vserver.
-vserver <vserver>
- Vserver Name-
Use this parameter to specify the Vserver on which the route is to be deleted.
-destination <IP Address/Mask>
- Destination/Mask-
Use this parameter to specify the IP address and subnet mask of the route's destination. The format for this value is: address, slash ("/"), mask. For example,
0.0.0.0/0
is a correctly formatted value for the -destination parameter. -gateway <IP Address>
- Gateway-
Use this parameter to specify the gateway on which the route is to be deleted.
The following example deletes a route within Vserver vs0 for destination 0.0.0.0/0.
cluster1::network route delete -vserver vs0 -destination 0.0.0.0/0
