The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver peer modify
PDF of this doc site
Creating your file...
Your file is ready
Modify a Vserver peer relationship
The vserver peer modify
command modifies applications of the Vserver peer relationship.
-vserver <vserver>
- Vserver Name-
Specifies name of the local Vserver for which you want to modify applications of the Vserver peer relationship.
-peer-vserver <vserver>
- Peer Vserver Name-
Specifies name of the peer Vserver for which you want to modify applications of the Vserver peer relationship.
-applications {snapmirror|file-copy|lun-copy|flexcache}
- Peering Applications-
Specifies the Vserver peer applications.
The following example illustrates how to modify applications that are part of the peer relationship between the Vservers lvs1.example.com
residing on cluster1
, and pvs1.example.com
residing on cluster2
cluster1::> vserver peer modify -vserver lvs1.example.com -peer-vserver pvs1.example.com -applications snapmirror
