cluster show
Display cluster node members
The cluster show
command displays information about the nodes in a cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the nodes that match this parameter value.
[-node-uuid <UUID>]
- UUID-
[-epsilon {true|false}]
- Epsilon-
Selects the nodes that match this parameter value. In a cluster, only one node can be designated as Epsilon at any given time. You can designate a node as Epsilon to add weight to its voting in a cluster with an even number of nodes.
[-eligibility {true|false}]
- Eligibility-
Selects the nodes that match this parameter value (true means eligible to participate in the cluster).
[-health {true|false}]
- Health-
Selects the nodes that match this parameter value (true means online).
The following example displays information about all nodes in the cluster:
cluster1::> cluster show Node Health Eligibility --------------------- ------- ------------ node0 true true node1 true true node2 true true node3 true true
The following example displays information about the node named node1:
cluster1::> cluster show -node node1 Node: node1 Eligibility: true Health: true
