The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun igroup unbind
PDF of this doc site
Creating your file...
Your file is ready
Unbind an existing initiator group from a portset
This command unbinds an initiator group from a port set. When you unbind an initiator group from a port set, all of the initiators in the initiator group have access to all target LUNs on all network interfaces.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-igroup <text>
- Igroup Name-
Specifies the initiator group that you want to unbind from the port set.
cluster1::> lun igroup unbind -vserver vs1 -igroup ig1
Unbinds the initiator group ig1 from the port set on Vserver vs1.
