      system snmp community show
Displays communities
Displays the current list of SNMP communities.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
Selects the Vserver to which the SNMP community belongs
- [-community-name <text>]- Community
Selects the SNMP v1/v2c community string
- [-access <ctype>]- access
Selects the access type of the SNMP v1/v2c community. Read-only (ro) is the only access type supported
cluster1::> system snmp community show
cluster1
    ro private
 PDFs
PDFs
